stock F4 fork height setting?
Old Aug 3, 2011 | 02:32 PM
segraves1's Avatar
Default stock F4 fork height setting?
Can someone please give me the stock fork height on an F4. Specifically, I need the distance from the bottom of the neck (from the lower bearing spot) down to the center-line of the axle. I can not use actual "fork height" as it would relate to triples since I am using a 929 triple and GSXR forks.
Old Aug 3, 2011 | 03:03 PM
MZ5's Avatar
MZ5
Please remember to specify how much static sag you want programmed into our answers.
I'll try to get a measurement for you tonight or tomorrow, if others don't jump in here first.
Old Aug 3, 2011 | 03:14 PM
segraves1's Avatar
ummmm. . . not sure..... I'm just trying to find a "stock" setting so I can have a place to start with. So whatever the bike would come with from the factory?
Old Aug 3, 2011 | 04:21 PM
gotcbr's Avatar
Chris,
From the underside of the lower triple (the flatest part), you're looking at 455 mm.
Old Aug 3, 2011 | 07:16 PM
segraves1's Avatar
Originally Posted by gotcbr
Chris,
Can you tell me how thick the lower triple is? I don't have my F4 lower triple anymore so I have to calculate my setup from the frame itself.
Old Aug 3, 2011 | 11:38 PM
gotcbr's Avatar
The lower triple thickness is 22mm +/-. To where it meets the frame, 25mm +/-.
Hope this helps.
Old Aug 4, 2011 | 12:26 AM
segraves1's Avatar
Yeah that helps a lot. So if I figure 480mm +/-, that should at least get me somewhere in the ballpark and able to go from there.
Thanks!
rozzilla
Jun 26, 2012 10:54 PM
jveach
Feb 11, 2012 06:30 AM
CbrRod
Jul 4, 2011 11:58 AM
Cdrisco2
Oct 8, 2010 07:37 PM
Kuroshio
Jul 24, 2009 11:36 PM
