sluggish?
RE: sluggish?
I'd try syncing your carbs first. It doesn't mean that its sluggish because you still have stock jets. I bet your carbs are unsynced causing the throttle responce to not be smooth especially in the lower RPMs. I bet it kinda hickups when you first going, sometimes you might here a little pop too.
RE: sluggish?
You need some vaccum gauges and a service manual. Its really simple. The vaccum gauges are gona cost you around $50-$100 depending if its digital, if it measures 2 or 4 at a time, etc.
http://www.motionpro.com/motorcycle/tools/syncpro/
I bet it will help your gas milage too.
RE: sluggish?
It would probably be cheaper to go to a shop and have them do it. You really don't need to do it maby a couple of times in the bikes life unless you work with a lot of bikes or put modifications on yours often. You'll most likely end up buying a new bike later down the road which will most likely be fuel injected and you'll never need the sync again. Waste of money.
