sluggish
Old Jan 7, 2008 | 05:27 AM
scottlan's Avatar
Default sluggish
hi ive got a cbr 600 f 1993 model well lookt after bike clean reliable but when im driving and pull back on throtel its a little slow on pickup its sluggish but when up to higher speed it returns to good power eny sugestions on wot problem can be much apreachated im a new rider so dont no where to start
Old Jan 7, 2008 | 09:16 AM
marc0011's Avatar
Default RE: sluggish
There could be several things causing this. I recomend starting with the easy stuff first, how old are the plugs? The air filter, is it old also? What about the fuel filter, have you changed it lately? If this doesn't sovle it, look for possible air leaks in intake (worn hoses, failing rubber garments, and etc). A little FYI, they can be a real SOB to find sometimes.
Old Jan 7, 2008 | 10:00 AM
MikeInCtown's Avatar
When you say higher speed, do you mean higher RPMs? If so, it's probably a carb issue with too much fuel at low PRMs. However, timing and spark need to be looked at.
First thing I would do is change out the plugs if you haven't done that recently.
Also, when you grab the throttle, what RPMs are you in? If you twist hard and are in low RPMs, it will take a few seconds for the engine to get going. If you are at 7k and grab the throttle hard, hold on.
xtreme89
Jul 21, 2009 08:38 PM
Cocky600
Aug 27, 2008 02:07 PM
cbr600joe
Jan 15, 2008 08:23 PM
JR Leonard
Nov 2, 2007 09:16 AM
bigwill2001
May 9, 2007 08:00 PM
