Slight stumble on takeoff
Old Jul 29, 2007 | 05:49 PM
Det99cbrf4's Avatar
Default Slight stumble on takeoff
Today i noticed sometime taking off the engine will stumble for a second and then be fine. Up in the rpm's/crusing it runs perfect. Also if i just rev it in netural is will stumble sometimes untill the rpm's increase. Any ideas? 12k miles, no maintence done thus far besides of course oil changed. New plugs already on the way.
Old Jul 29, 2007 | 06:04 PM
KasiNovaH's Avatar
Default RE: Slight stumble on takeoff
my 99 f4 does this occasionally to, doesnt really bother much though cuz it only happens once in a great while..
Old Jul 29, 2007 | 07:55 PM
*PHOENIX*'s Avatar
Might wanna check your idle speed is set correctly mate, there's a little black knurled *** down on the right hand side of the bike, just below the front of the seat, you don't have to remove theseat to see it.
Old Jul 29, 2007 | 08:09 PM
Det99cbrf4's Avatar
Yup its right at 1400
Old Jul 29, 2007 | 08:19 PM
*PHOENIX*'s Avatar
Might be an idea to clean the carbs along with changing your plugs then and see if that helps.
If you live in America I hear a lot of people speak quite highly of some stuff called sea foam for cleaning out carbs. and if you're doing the carbs and plugs then you might as well clean out the air filter too, just the general maintenance stuff to help it run a little better and see if it helps really.
Old Jul 29, 2007 | 10:44 PM
Det99cbrf4's Avatar
Thanks PHOENIX, my new plugs should be here wed, see how those help.
Old Jul 30, 2007 | 11:27 AM
Det99cbrf4's Avatar
Drove it an hr to work today w/o a hitch, maybe it just needed a good redline pull on the highway :]
jetson1000f
Apr 10, 2011 08:12 PM
Hardrock69
Jul 26, 2008 01:15 PM
Det99cbrf4
Sep 4, 2007 10:46 PM
mihomie
Jul 18, 2007 06:15 AM
929ER
Jun 2, 2005 02:25 AM
