seat lock
Old Nov 10, 2011 | 04:57 PM
rriver14's Avatar
Default seat lock
my cbr f4 seat comes right off without a lock is that normal for all models or im missin a lock somewhere ?? i couldnt find one and im scared someone will steal my helmet from the helmet lock
Old Nov 10, 2011 | 08:07 PM
gotcbr's Avatar
No, not normal. The lock mechanism should securely hold the seat.
Old Nov 11, 2011 | 10:51 AM
rriver14's Avatar
thanks and how do you lock it ?? i couldnt find the lock or key slot anywhere
Old Nov 11, 2011 | 01:04 PM
gotcbr's Avatar
Has your undertail been modified?
Show us some pics & we'll go from there.
Old Nov 11, 2011 | 02:36 PM
CDN in GND's Avatar
I've got a funny "locking mechanism" for my seat.
It's this small little **** on the left side of the passenger seat. It doesn't lock in the conventional sense, but rather just prevents the seat from coming off randomly.
You open it via pulling on it. My bike is new to me, so I wasn't sure if this was just a 1999 F4-thing.
Old Nov 11, 2011 | 03:01 PM
platnumbob's Avatar
The lock should be right below the licence plate; as gotcbr is indicating many people modify thier undertails which usually leads to a removal or relocation of the lock mechanism.
Old Nov 11, 2011 | 05:00 PM
CJardine's Avatar
Track junkie & modaholic
if its not near the lisence plate check the undertail near the center. A lot of aftermarket ones will put it there, If not you can pick up a lock off of fleabay for cheap and drill a spot for it.
Old Nov 11, 2011 | 08:39 PM
gotcbr's Avatar
Originally Posted by platnumbob
...gotcbr is indicating many people modify thier undertails which usually leads to a removal or relocation of the lock mechanism.
^ This.
^ I actually had mine set up this way when I still had the banana seat & tail (I've since converted to split-seat). Anyway, I had a homemade sheet aluminum fender eliminator. Instead of having a lock, I had the nub (as I call it) that's on the end of the lock's cable extending thru a cut slot in the FE, to the outside of the FE. When I wanted to remove the seat, I simply pulled that nub. It would actuate the seat lock just like the key. It worked great. Nobody knew what it was but me. Since pics tell the story, I'll attach a pic below...
Old Nov 14, 2011 | 04:30 PM
rbjeepthing's Avatar
^lol I have mine the exact same way
MistahJuice
Jan 2, 2014 12:59 AM
NewSense45
F4i - Wanted
May 16, 2012 10:05 AM
linwoodc3
Mar 28, 2012 11:25 PM
huggieboy
Aug 19, 2010 09:37 PM
TaoistTattooist
Aug 26, 2009 11:14 AM
