Regulator and Starter issue. Any tips?
Old Aug 20, 2017 | 04:40 PM
Stian Frank Amadeus's Avatar
Default Regulator and Starter issue. Any tips?
First I thought my battery had died when the starter was slow. But after runstarting it and driving it to the garage I saw that the voltage was at 13.6 with the ignition on. And later when I tried to start it the starterrelay just made a fast-paced clicking noise. Later when I was on my way home, I was reving it, all the headlights went dead, and the speedolights started flickering, and then the engine died.
And after I got it to the garage, the fuelpump didn't stop making a sound. Am I wrong when I think it's the regulator and starterrelay that's fried?
edit: It's a '99 F4
Result 1 week after original post:
I bought a new Rectifier and battery. Started with no delay, and running smoothly!
Now it runs like a charm
Old Aug 20, 2017 | 05:33 PM
74demon's Avatar
Sounds like a bad battery. Replace it or verify it's in good shape and go from there.
Old Aug 21, 2017 | 10:48 AM
VeritasArchangel's Avatar
Was that 13.6 with the engine running? You can only check stator and regulator with engine running. And, was the issue with the fuel pump running with the key on or off? The fuel pump should only run when the engine is running as well. If it is running while the key is off then it sounds like a switch issue. I would be double checking grounds as well.
A dead battery will not make the fuel pump stay on, and neither will a bad stator and/or regulator.
Check the voltage at the battery with the bike running, if you get 13-14 volts then the stator and regulator are working. Then, with the bike off, check the voltage. Wait a couple hours and check the voltage at the battery, with bike off, if the voltage has dropped significantly the battery is dead. You can do the same test, after charging the battery to full with the battery unplugged. if the battery doesn't drop the same when it's not connected, then you are probably dealing with a short in the system causing a draw.
The fuel pump running thing is what is more concerning, as all other issues can be related to simply a bad battery.
Old Aug 22, 2017 | 09:18 AM
it was 13.6 with the engine off. And when I turned on the lights it went down to 8.something.
and the fuelpump started ruinning after the bike broke down, when I tried to turn on the ignition. I took the battery out, and it was bent at all walls, so the battery was most def dead.
EL Thorsby
Jun 1, 2011 03:04 PM
ShadyOne13
Mar 27, 2010 04:44 PM
Daniel.Hennessy@va.g
Sep 27, 2008 12:24 PM
rrrobert
Jul 10, 2008 07:56 PM
