radiator fan problem
Old Nov 19, 2006 | 12:36 AM
CBRF4's Avatar
Default radiator fan problem
I bought the bike with the radiator fan hooked up to a switch and it works and everything but the problem is that when the bike is on idle for like 2-3 min the bike would turn off
i tried puting it back the way it should so it can turn on by itself, and the fan wount turn on i checked the fuse and there is nothing wrong with it.
can anybody tell me what could be wrong/ thanks in advance
Old Nov 19, 2006 | 01:42 AM
zerochickenstrips's Avatar
Default RE: radiator fan problem
Sounds like a bad ECT (Engine Coolant Temperature) switch. Its usually located on either the right hand or left hand side of the radiator.
Old Nov 19, 2006 | 05:08 PM
CBRF4's Avatar
does it go bolted on the left side of radiator and only one cable gooes to it, the one that produce ground to the fan because i replace that one but, i was reading a little bit about other people that had almost the same problem as me and they said that since i replace the ECT(well that what i think it is) i had to bleed the system or something like that i havent done that jet so im gonna try it. thanks for the help
Old Nov 20, 2006 | 12:40 PM
Yes there should be only one thing attached to your radiator and that will be the ECT. It is possible that you have an air pocket in your cooling system. Should be able to bleed it out by running the bike with the radiator cap off for about 1 minute.
Old Nov 20, 2006 | 01:51 PM
Tahoe SC's Avatar
yes...run it off but also rev the **** out of it...revving opens up the t-stat and pushes all bubbles out...
Old Nov 20, 2006 | 10:30 PM
CBRF4's Avatar
ohh ok got it so all i got to do is run the bike rev it it for like a min or two with out the cap. is it gonna drip the fluid out do i need to get some radiator fluid just in case? thanks alot
Old Nov 20, 2006 | 11:06 PM
The thermostat won't open until a certain engine coolant temp is reached, usually around 160 deg. F. If you run it without the cap until the thermostat opens up, you'll know when the thermostat opens b/c the coolant inside the radiator will be flowing instead of just kind of vibrating. It is possible that you will lose some, but it shouldn't be too much.
Old Nov 21, 2006 | 12:25 AM
CBRF4's Avatar
ok thanks ill let you know what happens just in case i need more help thanks again.
weston123
Apr 30, 2013 06:30 PM
Cytotek
Jun 16, 2010 11:10 PM
chuck1985
Mar 14, 2010 11:11 PM
whtan20
Aug 12, 2008 10:39 PM
sasakiman
Oct 29, 2006 01:28 AM
