putting 2004 rr rims/tires on 99 f4
can it be done without to much hassles? just bought the bike its in the shop getting it running im just trying to figure some stuff out on it. came across a guy who has some 04 rr chrome rimes and tires for super cheap but i dont know if they will fit on f4 99......also how can i tell what size sprocket is on it ..do i count the teeth ?
I'm not sure about teh rear, but I don't think the fronts will fit unless you change the front suspension.. I believe that the F4 has different forks, wheels, and rotors from teh F4i, so I assume the same holds true for the RR. Then again, I'm still a newbie to the CBR world.
Adam
Adam
the RR rear wheel has a larger diameter axle that wont fit thru the stock swingarm. I think the bearing races are the same tho, so you should be able to swap the bearings out n use the F4 axle then. Or just do a RR swingarm swap too
