Problem with carbs???
#22
RE: Problem with carbs???
I've had the same issue with my f4i, where the battery connection got loose, and my bike was stuttering when giving it constant throttle. Nothing as extreme as yours, but definitely noticeable. Not sure if that will completely solve your problems, but hopefully it will address some of them. Good luck.
#23
the only reason i am convinced is because it did the hesitation over bumps, other then that i guess time will tell...another question, where your positive and negative connections are, is there a nut underneath of the little tab that you have your grounds to? or is a welded nut underneath? i just dont know how to secure these things down so this wont happen
