Possible blown spark plug
Old Sep 27, 2011 | 10:21 PM
kapsiak's Avatar
Default Possible blown spark plug
I think that i may have a blown spark plug but I'm not sure. Can some one help me figure out if I do have. The bike makes a ticking sound and the black spark plug sleeve is jumping up and down. If it is a blown spark how do you fix it?
Old Sep 27, 2011 | 11:07 PM
kilgoretrout's Avatar
Administrator - Retired
Remove the wire, inspect the well, remove the spark plug, and have a look at it. If you can physically see the plug wire jumping up and down.... you have a problem that needs addressed now.
Old Sep 28, 2011 | 05:54 AM
kapsiak's Avatar
Yea I don't know what the problem is lol.
Old Sep 30, 2011 | 03:46 AM
DonnyBrago's Avatar
Reseat the plug cap to get it securely back onto the plug, see if it still does it - if it does then remove the plug, check the threads, check for bits of aluminium in the thread suggesting you have stripped the cylinder head, change the plug, fit it properly - i.e. finger tight then 1/2 a turn, refit the plug cap and see if it still does it.
The reasons why the the plug cap could be moving are:
1 - because either the plug is loose in the head and being blown around
2 - the plug is fitted badly/stripped out so that pressure is blowing past and making the cap wobble around.
3 - the plug cap isn't on properly meaning it is shaking about with the vibrations of the engine.
LilRed F3
Mar 7, 2012 03:25 AM
LilRed F3
Mar 3, 2012 12:25 AM
unicorncane
Dec 6, 2010 08:35 PM
ryano900rr
Oct 31, 2009 02:14 AM
allnath3
Nov 5, 2006 12:31 PM
