How do i turn it off? I have a pinched fuel line after it i need to change out. So i turned it clockwise i think and tried to take the line off and gas spilled out. Thanks for the help.
on, res, and off those are the only settings for the pet **** if none turn gas off at the tank, then you have a bad valve, you will need to drain the tank and replace the bad valve and your pinched line[sm=signs003.gif]
