Seat Shaving
Old Mar 1, 2006 | 04:33 PM
EVOLMTR's Avatar
Default Seat Shaving
Hello all, I was curious if anyone has shaved their seat to lower the bike a little (1 inch) and if so, did it help you out. I don't want to have to lower the bike through the lowering link and then lower the front as well because the handling of the bike. Thanks in advance.
Old Mar 1, 2006 | 05:55 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Default RE: Seat Shaving
I've heard of this but can't find any info on it. Seems like the seat would be really uncomfortable if you took out 1 inch of foam. Have you looked into a little taller boot?
Old Mar 1, 2006 | 06:17 PM
EVOLMTR's Avatar
I haven't looked into a taller boot yet but I will look into it thanks. I hope someone can chime me in on their experience with shaving the seat.
Old Mar 5, 2006 | 03:52 AM
wood83's Avatar
i dont get it if you shave the seat you just lower where you sit the bike is exactly the same
Old Mar 5, 2006 | 12:56 PM
ORIGINAL: wood83
Some people aren't as tall as others and would be more comfortable (especially at stop lights) if they were closer to the ground. Lowering the seat height an inch will lower the rider the same amount as lowering the suspension 1 inch but it won't affect handling.
Old Mar 5, 2006 | 02:30 PM
wood83's Avatar
I get it i figured it out right after i posted it i am 6 3 and every one i ride with is pretty tall also so that has never been an issue. But i would think lowering the bike would be better for that reason anyways. Our seats are kinda hard to begin with. Cant you lower the bike from the rear shock there is two nuts on the coil that can be adjusted it is just like a car with lowering struts
Old Mar 6, 2006 | 05:42 AM
Downforce137's Avatar
a friend of mine shaved his Katana seat down, and had some gel inserts installed. Overall he prolly had 2 inches of foam cut out, and 1/2 to 3/4 of gel reinstalled.. Yah.. hes gellin like magellan..
Old Apr 14, 2006 | 02:47 AM
sdsheeks's Avatar
ORIGINAL: EVOLMTR
I just shaved my seat. I removed the seat from the bike, took the mounts off and removed all the staples. I then used a power knife and cut about 2 1/2 " off the front (where I sit) and then used a really good powerful stapler to put the thing back together. Remember to cut from the bottom because it won't be smooth like the top. I'm about 5'7" and I can now touch the ground a LOT better than before. I cannot really move the bike with my feet if there is any hillage, but it is better at the lights and turns. Just remember to use a good stapler and cut from the bottom. It is pretty easy and should only take an hour or so.
PS. With 2 1/2" of foam removed the seat is actually a lot more comfortable! Believe it or not that stuff is hard.
Good luck.
Dave
Alex Rivet
Jan 18, 2014 01:15 PM
98F3_colorado
May 17, 2011 10:08 PM
woodypk
Mar 30, 2011 02:10 AM
tdiddi
Oct 2, 2007 03:08 PM
F4iGuy33
May 23, 2006 12:27 PM
