overheating problem!!!!
Old Apr 24, 2009 | 09:25 AM
cbrsi's Avatar
Default overheating problem!!!!
hey, i m new to this forum .. this is my first bike, 2000 cbr600f4, and i dont know what the problem is.. when i ride its fine when i stop after riding the c-h meter starts to rise.. and when it get near hot it starts to spill coolant.. then i realized the fan is not turning on, so i went i bought a new fan motor,, still not working, i recently just ordered a new temp sensor switch so .... if anyone knows what i can do to fix this , because im kinda scared to ride it on a hot day, afraid of over heating when at a red light for 2 min .. ,,
plz i need help thank you
Old Apr 24, 2009 | 11:17 AM
MartiniRossy's Avatar
Check fuse D, make sure the motor switch is grounded well and the connector is plugged in all the way and making a good connection.
Old Apr 24, 2009 | 01:14 PM
cbrsi's Avatar
hey sorry im new to bikes.. and where do i check the fuse and such
Old Apr 24, 2009 | 01:55 PM
yog182's Avatar
Fuses are under the seat behind the battery... Good luck
Old Apr 24, 2009 | 06:58 PM
KLO's Avatar
KLO
congrats on the cbr!
as to ur over heating problem, you would want to do check the fuse first under the seat.
Just take the seat off, and u shud be able to see a box that holds the fuses near the sides.
if the fuses are good, most likely it is going to be the fan motor or the temp sensor switch in the radiator.
u can check to see if the fan motor works by taking the wire that connects to the switch and ground it to the bike. turn the key on, and if the fan spins, 97 percent chance that the temp switch went faulty. It happened to mine.
After a new switch, it should work good. Good luck wit it.
Old Apr 26, 2009 | 06:52 AM
honda f4's Avatar
the best item i bought with my bike is a clymer book , it gives step by step
since you are new i would highly recommend. i use the crap out of mine
tyler8471
F2 Tech
Aug 11, 2010 04:59 PM
dinez74
Oct 11, 2007 09:52 AM
travisgarrison
Aug 31, 2007 03:58 PM
Clipse3GS
Apr 7, 2007 10:43 PM
capa112
Nov 1, 2005 06:45 PM
