do i need A stator
Old Apr 18, 2009 | 04:17 PM
Omarlito21's Avatar
Default do i need A stator
So my bike was running fine would start perfect everytime so last week i went to start it and the battery was completly dead so i brought a battery charger/tender and it charger the battery turned it on and it was ok again i rode it around parked it for half an hour and it almost dident start i left it alone and after a an hour or so the battery was dead again......now i heard that with the bike running if you disconnect the positive wire your bike should stay on and if it turns off your alternator in messed up is there any truth to this do i need a new stator? i was on bike bandit and there are 2 main parts the startor and the flywheel do i need both?? also is this a do it yourselfer thanx in advance
i have a 2000 cbr 600 f4
Old Apr 21, 2009 | 05:50 PM
vforce30's Avatar
In my experience with Honda charging problems it is more likely the voltage regulator. You should check the output voltage to the battery with the bike reved up. There are upgraded regulators available that have more cooling fins and I have used a Yamaha F6 regulator which is more durable than the Honda and usually reasonably priced on Ebay.
Old Apr 21, 2009 | 09:27 PM
cbtrez's Avatar
Yeah, My voltage regulator was fried and it killed my battery. Its a common problem with 90s-2000 Honda's. There are after market voltage regulators/rectifiers that have better cooling, ie fins etc. Here are one of the after market ones if you dont want to mess with your bikes wireing. http://www.electrosport.com/products...etail-1832.php
To check your regulator rectifier get a multi meter, and shoot Ohms across 3 yellow connection, or across anything if you have infinate ohms, meaning max resistance its fried.
Old Apr 23, 2009 | 04:36 PM
ford_loomis's Avatar
I'm guessing voltage regulator, it happened to my old 96 900RR. I replaced the stator first only to find it still wouldn't stay charged, regulator fixed it though. The F4 is getting up there in years so replacing both probably wouldn't be a bad idea either, then you'll know your charging system is good for another decade.
Old Apr 24, 2009 | 09:04 AM
TikkiTakki's Avatar
Hey guys, where is the RR located at on the F4?
UPDATE: I did a little poking around and I assume that it is the 3X3inch or so box bolted to the right side frame, around the passenger seat area.
Old Apr 24, 2009 | 07:02 PM
saetneta's Avatar
Are you sure your battery is good? Even if you can charge it, it may not hold the charge that long....
Old Apr 25, 2009 | 01:04 AM
Omarlito21's Avatar
changed the regulator rode it and left it a couple of days without the battery tender and it started right up today thanx alot guys.......loomis ill change the stator in the winter just to be ready for next yr thanx now for a good riding season
Old Apr 26, 2009 | 10:01 AM
camaropower's Avatar
My 900rr just did this exact same thing when I was driving. Stopped at a rr crossing and it died, not to e started again. When I got it home, I checked out the stator, and its wires were holding on by a thread, and had shorted out
kennygilliam
Dec 31, 2008 11:02 AM
slutty62cont
Aug 14, 2005 01:06 PM
slutty62cont
Aug 14, 2005 03:11 AM
