Ok guys really need some opinions please!(begging)
Old Jun 2, 2008 | 09:57 PM
jessej05's Avatar
Default Ok guys really need some opinions please!(begging)
Ok all started saturday night while riding to pick up my newly painted tail fairing on my 99 f4 red/black. Pull over to get gas and put it in neutral. Only the light wont come on so I reached down and put it in by hand,(thinking I was just missing it). Still no light. So get gas and take off only to see that nothing on my gauges work. No : temp,rpm,mph,turn signals,brights, nothing. So I kept going making sure to feel if the bike was getting hotter or not. Ran like a champ. Got back after picking up the peices 1 hr ride. Still nothing worked. Soon as I got back I realized my tail light and brake light was not working. I checked the 4 fuses under the seat and the main 30 amp and all check good. I even wiggled them a lil. Now it wont start. The only thing that works is my headlight and brights. This is so weird and I am taking it to the shop tommorow. BUT any ideas? thanks fellas ( thank god this site is working right again.)
Old Jun 3, 2008 | 08:33 AM
gr8shot's Avatar
Default RE: Ok guys really need some opinions please!(begging)
Wow thats a tough one! I had a similar thing happen to my bike. The gauges and tail light stopped working, but it still ran fine, and the fan kicked on if it got too hot. BUT, it was just a fuse under the seat that kept blowing. You might replace the fuses anyway and see if it helps...? Idk. One could have gotten cracked or something. Just a guess though. Good luck with the shop otherwise. []
Old Jun 3, 2008 | 09:41 AM
tecnica's Avatar
Same thing happened to me on the highway yesterday (nothing like killing your brake and turn lights doing 75). I took it home and standing on the left side of the bike looking at the fuse box, it was the second one down. Yours may have popped and you just cant see it. But it took out my gauge cluster, turn and brake lights - just like you. My headlight also stayed functional. I'm almost 100 percent sure this is your problem. As for your bike not starting, the top 10 fuse is ignition. You probably broke it wiggling and taking it out. Just replace both of those and make sure there is not corrosion in the fuse box under the fuses. No need to panic my friend.
Now determining this problem is a different scenario. I don't know what caused it other than it was a hot and humid day. I put 3 extra spares in there just in case this happens again when I'm not so close to home.
Old Jun 4, 2008 | 04:40 AM
jessej05's Avatar
Awesome thanks guys. Its already at the shop hopefully I can go check it out while its there deff gonna try those two fuses. Is it possible for a fuse to be blown but the middle indication strip is not burnt? I guess it is idk.
Old Jun 5, 2008 | 09:52 PM
jessej05's Avatar
ya that was the fuse, it only had a small little dot that was burnt. the fuse just didnt melt like it was supposed to. All good though!!!!
Old Jun 5, 2008 | 10:36 PM
tecnica's Avatar
glad to hear it was something cheap
Old Jun 6, 2008 | 11:25 AM
jessej05's Avatar
thanks bro your a life saver
Speedemon636
Aug 3, 2009 09:33 PM
RaceIt454
Jul 30, 2009 08:29 AM
sjpd13
Sep 4, 2008 07:26 AM
Draco88
Mar 11, 2007 02:57 PM
Rev
Jul 31, 2005 11:57 PM
