oil out light on question
Oil light will usually be on with the ignition on and engine not running = no oil pressure means the sensor is going to trip the light.
With the ignition run switch in the off position, crank the bike over for 4-5 seconds - the oil light will usually go out as turning the motor over has circulated enough oil to build up pressure.
I'm with iJapanesey - we need more detail about what is happening, your post isn't very descriptive.
sorry i been workin the past 48 hours ...
i empited the oil drop the drop bolt and i took the stator cover off cause i noticed it was leaking, after i changed the oil (did not put oil back in till it set for 24 hours to seal) i turned the on and tried 2 start the bike and noticed the red oil light was on and when trying 2 start it made a whining noise like it was trying 2 circulate the oil but nuttin happen it doesnt turn over
oil light is going to be on unless the motor fires up. It may go out while cranking, but let off the starter and the light should come back on. If the motor isn't running, there is no oil pressure. No oil pressure means that light should come on. both of the other bikes in your sig should act the same way.
you say the bike "doesn't turn over". to most people, that means when you press the starter nothing happens - the starter motor isn't turning the motor over. Is that what you mean?
ok i put it back together put the oil in .. when i turn the key on it shows the red oil light .. when i try to start it the stator is moving i can hear it .. but the red light stays on i held it for about 20 secs nuttin changed.. tried again same results ... the batteries fine i can flip the highbeams on and off try starting it and the lights arent dimming
