Mototeck Undertail Install Help Needed
Old May 30, 2007 | 07:53 AM
alfordsiler's Avatar
Default Mototeck Undertail Install Help Needed
Ok, so I am installing my undertail and I get the fender cut off and everything is going just fine. I put the rear fairing back on and slide the undertail in there to see how it fits and everything looks great. Then I look at the instructions which I got from the How-to section. (https://cbrforum.com/m_154971/tm.htm) and the next step is to "mark holes in the undertail with the holes in the cowl so they align properly."
Uh, this is where I am lost. Where exactly are these holes supposed to be marked and drilled. The only logical location is where there were originally two clips (see pic 1). I obviously have to drill holes there for the original clips but where do the other holes go to be bolted to the fairing (see pic 2)?
The undertail came with 4 screws, 2 with rubber bushings (they call them rubber nutserts) and 2 with a washer and nut. Where in the world do these holes and mounting screws go?
Please help!
[IMG]local://upfiles/16279/FB1FE07E703547E3A5618F8265D43044.jpg[/IMG]
[IMG]local://upfiles/16279/15AEA737F150499E8F780D8E8CDE1E8E.jpg[/IMG]
Old May 30, 2007 | 11:52 PM
ajlong's Avatar
Default RE: Mototeck Undertail Install Help Needed
I have the same under tail and the only holesto drill are for the license plate mount. There is already 3 little dimples behind the seat lock key hole. The one in the link is a different undertail than ours.
alfordsiler
Apr 15, 2011 06:05 PM
blakesgst
Oct 25, 2009 12:01 PM
jstew600
Jan 12, 2008 07:31 PM
929 FRB18
Jun 22, 2006 09:53 PM
