lowering the front
Old Apr 25, 2011 | 11:00 PM
mbrown22's Avatar
Default lowering the front
im putting lowering links in tomorrow and didnt know how i would go about lowering the from of my bike and how to make shure its all level
Old Apr 26, 2011 | 11:15 AM
polish man's Avatar
u need to raise the front end of the bike and slide the fork tubes up in the tripple clamp you want to keep the drop even with the rear. just measure each side alot befor you tighten every thing down, then put your flame suit on cause you will prolly have someone hatin on you lol
n you dont wanna go below 1.5'' or you may run into problems
Old Apr 26, 2011 | 11:23 AM
mbrown22's Avatar
Lol thanks a lot man
Old Apr 26, 2011 | 02:34 PM
ohio nitro's Avatar
i lowered mine 3 in the rear and 1 in the front bike tears through the corners as well as it did at stock you may have to adjust the shocks a little bit but keep track of where you start and write it down so if something is not the way you like it you can go back
Old Apr 26, 2011 | 05:36 PM
mbrown22's Avatar
well i just lowered it and now i have ran into kind of a problem it seems my damn kick stand is to long and my bike kinda stands strait up and is easy to tip over is there sumthin to do here or do i just buy the adjustable kickstand?
Old Apr 27, 2011 | 11:17 AM
polish man's Avatar
you got to cut it down and weld the flat part back on the bottom cut alittle off at a time to test where you want it then take it off n get the bottom welded back on, or you can go adjustible but that cost more. when you cut it do it on concrete so it doesnt stick in the ground n fall over
Old Apr 30, 2011 | 01:01 AM
LCRF4's Avatar
I'm down 1.5" up front and up .5" in the rear... my bike turns in fast as hell
Old May 31, 2011 | 07:47 AM
marw1980's Avatar
I recently lowered my gf's '99 F4. The new brackets for the rear lowered the bike 4cm and it was also suggested to lower the front 1cm on the fork tubes wich i did. The bike handles fine to my surprise. She is 155cm and barely reaching down even with extra soles on the boots, hehe.
BTW. I solved the kickstand issue with a steel pipe, extending the stand so I was able to bend it a little forward and outward. It's not in the way of anything while riding and it will be cheaper to bend it back when she's gonna sell it.
Old Jun 1, 2011 | 07:19 AM
UnderAssumedName's Avatar
Mine isn't lowered but I'm sure I saw a "Lowering do's and don't" thread somewhere here. I read that yumoncbr (600RR) got her kickstand bent somewhere instead of getting a new one or welding the OEM one.
jtboyd91
Jul 23, 2010 08:24 PM
CBRme
Feb 11, 2010 12:02 AM
G3NESYS
Apr 3, 2009 01:12 AM
Doodie
Sep 3, 2006 02:58 PM
Eric CBR929
Aug 4, 2006 06:33 PM
