low fuel light wont work
Old May 18, 2009 | 08:56 AM
patrick12's Avatar
i am glad the bulb is not out because as someone posted somewhere there is no way to get to the bulb
Old May 12, 2013 | 09:41 PM
BarrelRoll's Avatar
New Member
I was curious about this and I missed the section of the service manual where you could just short the two wires together at the sensor to test it so I pulled the gauges apart and the low fuel light is in fact not one but a pair of LEDs!
Old May 16, 2013 | 07:33 AM
Dean0's Avatar
Just to add to this testing discussion - the light is not instant when you join the wires to test it.
It has a delay timer in the clocks - the light can take a minute to come on after the wires are joined together.
Old May 17, 2013 | 11:23 AM
jsowden42's Avatar
can anyone tell me which wire goes where lol I took the tank off and dont know if I hooked it back up right, will not know until a while lol which color goes towards the front of the bike? Thanks guys this would save me some time.
Old May 20, 2013 | 09:45 PM
patrick12's Avatar
If I remember right, it didnt really matter where the wires hooked up. It should be just like a light switch. It will work either way.
Old May 21, 2013 | 08:33 AM
jsowden42's Avatar
ok thanks
Old May 18, 2020 | 06:28 PM
AxeMan 929RR's Avatar
Default Here's the only one I can find.
we drained the tank yesterday and it still wouldnt work so we pulled a few things apart and did some tests
turns out it was the fuel reserve sensor that needs to be replaced it is broken
it is really really simple to fix its just a matter of unscrewing the part and putting the new one in
now i just gotta find one
thanks a lot for your help guys
the sensor in the tank i's called a thermistor and after much searching online and several fruitless aggravating phone calls with parts houses I finally found one on eBay that was listed for 69 to 73 mustangs and cougars. The item number on eBay is 372154702745, it is absolutely identical to the sensor in our fuel tanks so the only thing you'll have to do to put it in your bike is unsolder the old one from the bracket then put the new one in the bracket and resolder it and then remount the bracket onto the fuel pump assembly and connect the wire.
C Jacob W
Jul 29, 2013 11:03 AM
mbrown22
Feb 11, 2011 11:14 AM
eric_5000846
May 28, 2009 12:56 AM
jayems301
Nov 4, 2007 07:41 PM
thunderstruck
Mar 3, 2006 09:43 PM
