Help! Not Starting
Help! Not Starting
I tried to start my bike the other day and when i turned the key on the headlight didn't come on, and it isn't getting power to the starter button. I started and rode it the day before. All of the fuses under the seat are all good still, is there another fuse block on the bike somewhere. Or has anyone else ever had this problem. Any help i can get i would greatly appreciate. Thank you in advance.
RE: Help! Not Starting
i had the same problem the other day. i lifted up the seat to check the connections on the battery and they were good. then i saw the ignition fuse (10a) is on the left side bought half way up the seat. theres like 4 other fuses. none of them were blown so i was like well maybe if i wiggle it then try again. NOTHING so i tried again and sure enough fired right up. it was weird because everything was fine and then i turned the key to on and nothing. but no problems again.
