Help! New Battery, drains after a while
Old Apr 3, 2014 | 08:50 AM
katt72's Avatar
Exclamation Help! New Battery, drains after a while
I bought a new battery about 2 months ago. Since, I've had the battery die twice in the last 2 weeks. I have charged the battery once, since it died. What could be the issue?
Old Apr 3, 2014 | 09:10 AM
74demon's Avatar
The bike may not be charging.
Old Apr 3, 2014 | 09:53 AM
katt72's Avatar
74demon, would it be my stator or R/R that would cause this issue?
Old Apr 3, 2014 | 12:49 PM
74demon's Avatar
Could be either or both.
There are some links to stator and R/R testing all over this forum. Grab your DVOM and start testing...
Old Apr 3, 2014 | 03:02 PM
katt72's Avatar
I will test the stator and the R/R. Hopefully that will tell where the issue is.
Thx, Demon
Old Apr 4, 2014 | 05:23 AM
markybwoi's Avatar
put money on it being the RR its a common problem with hondas. ive changed mine numerous times,
its an easy test just check the voltage coming into the battery to ensure it is charging correctly.
remember to the RR doesnt charge on idol you will need to bring the revs up while checking.
good luck
Old Apr 6, 2014 | 01:04 PM
CJardine's Avatar
Track junkie & modaholic
While yes it is probably the R/R The main reason for them failing is that the stator is on its way out.
Snotcycle
Jun 19, 2012 11:54 PM
ian1001
Jan 28, 2012 03:08 PM
cpm3rd
Aug 8, 2011 06:41 PM
jharbinson
Dec 31, 2009 09:23 AM
JJHUNSECKER
Aug 6, 2006 02:36 AM
