help...best way cutting fairing for frame sliders.
with a lighter n a butter knife.
nah j/k search it, there are quite a few how to's on this in the how section. Look em over n find which seems easier for you.
I have vortex, and I installed the bases and held my lower fairings in place apllyin pressure where the slider base was. This left an impression in the form backing on the fairing. I center took a hole saw, centered it, and drilled my hole. The size hole saw I used is just a hair bigger than the OD of the slider puck. I have zero clearance around the pucks when everything is installed. Looks very clean.
https://cbrforum.com/m_55748/tm.htm
Just follow this. I have a post on here on how I did mine. All you need is some chalk.
