Headlight dosent work nemore:(
Old Apr 23, 2009 | 05:07 PM
TankF4's Avatar
Default Headlight dosent work nemore:(
Just quit working one day and I changed the bulb still nothing. Power comes through to the plug, and we tested the bulb on another bike and its good. What could be wrong?? A short maybe?? Thanx in advance.
Old Apr 23, 2009 | 11:28 PM
2005RX8's Avatar
Hey just experienced the same problem. Press the starter slightly down...get someone to stand in front of the bike or look yourself to see if the light comes on....if so then Go to the starter "box" right by the right hand grip. Unscrew the two bolts and press down on the wires connected to a plate in there....there should be two white clips holding the sides down...if any are broken...fix accordingly
Old Apr 24, 2009 | 11:32 AM
MartiniRossy's Avatar
[QUOTE=TankF4;774989]Power comes through to the plug, and we tested the bulb on another bike and its good.QUOTE]
If you have 12 volts between either of the two +12v and ground then the connector is making a bad connection to the bulb pins. Check the ground wire just for giggles. I assume you tried high and low?
prowheelie92
Jun 4, 2010 04:56 PM
draggo5555
Jul 29, 2009 05:22 PM
MotoDan
Oct 17, 2008 11:12 PM
crookedeyemotocross
Jul 26, 2007 05:23 PM
Ride till I Die
Dec 2, 2005 01:51 AM
