Headlight/carb question?
Old Oct 6, 2007 | 05:37 PM
Bertski077's Avatar
Default Headlight/carb question?
watsup guys i appreciate all the feedback i got on my last post. i got a few more questions. on your guys' bikes when your in neutral and you hit the gas does the light get brighter? and how hard is it to sync carbs, do you need a special tooL? thanks alot.
Old Oct 6, 2007 | 05:46 PM
toaliosis's Avatar
Default RE: Headlight/carb question?
I've noticed that my light(s) do get brighter when I rev the engine.
Probably because you're makin more juice from the engine turning faster, thus turning the alternator/generator faster.
As for the sync-ing of the carbs, I think you need a set of vacuum gauges (4) so you can set them all to the same vacuum pressure.
I know there's some info on the forum concerning this, try the search.
Old Oct 6, 2007 | 06:17 PM
crodz600f4's Avatar
It's not too hard to do but youdoneed carb synch gauge. There are a variety of types... theone I have is from motion pro. Once you have the hoses hooked up then just follow thecarb synch instruction in the bike service manual. And that's basically it. It takes me about an hour to synch (but I go slow). When you put things back together, double check thatall the hoses arein the right places.
And yes, my lights gets a little brighter also.
odano1988
Sep 15, 2015 07:26 AM
CBRmax
Nov 26, 2009 07:15 AM
sempul
Sep 11, 2009 09:38 PM
SIRR1
Oct 11, 2008 11:26 AM
matthew2t
Dec 22, 2005 07:07 PM
