Grip removal
ok fellas i searched everywhere and cannot figure out how to remove the left hand grip so that i can replace the choke lever, already took off everythingi needed to take off, i just need to remove the grip to slide the lever out..Please dont tell me it is glued on either :/...
on
1 Post
I just did this.. remove bar end... use small reg screwdriver to make a space between clipon/throttle tube and grip.. insert WD40 tube into that space.. spray one quick spray... spin and remove.. . you might need a spray at opposite sides.. 10 min total to do both sides on mine.. clean all of the old glue off with brake cleaner
If you have an air compressor you can use that instead of wd40, both work but the new grips tend to spin if you don't clean the tubes super carefully with thinner, xylene or some other potent solvent. The compressor thing requires a bit of fiddling but it can be done. It's fun to remove grips from a cross bike's bar with the compressor, they go POP and literally fly off.
![Icon That](https://cbrforum.com/forum/images/smilies/icon_that.gif)
eekenterprises
01-19-2009 09:05 PM
