Fuel Pump
Old Oct 5, 2008 | 12:09 PM
bigtimcbr99's Avatar
Default Fuel Pump
I think my fuel pump has died... Every time I try to kick her over it sounds like one om my relays keep blowing. It makes like a Electrical shock sound. And sometime a buzz. There is no fuel geeting out of the tank. I turn the petcock on and the fuel dont even get to the filter. But the petcock works. I am stumped on this one...
Old Oct 5, 2008 | 10:51 PM
Nsracing33's Avatar
Default RE: Fuel Pump
Its normal for the fuel pump to make a clicking sound when the key is turned on. Not quite sure about the buzz. From what I understand, the fuel pump only primeswhen the bike is started.When the effluent hose off you should be able to see a little fuel come out when it primes. If not I would probably guess that its a bad pump, unless you somehow got a blockage somewhere in the fuel lines. Id order a new filter as well.
Old Oct 6, 2008 | 12:00 AM
I have put a new fuel filter on there already... I did have to cut a peace of the fuel petcock hose because when I was synching the carbs it broke off...
Old Oct 6, 2008 | 07:48 AM
toaliosis's Avatar
So are you saying that if you disconnect the hose from the petcock, then open it no fuel comes out of the valve?
Old Oct 6, 2008 | 09:31 AM
jonld's Avatar
ORIGINAL: toaliosis
Thats what I got from it too. Your fuel filter should be between the tank and your pump, pump to carbs. If your not getting fuel to the filter, you got a stopped up petcock or an empty tank. If that the case your starving the fuel pump which will likely burn it up shortly.
Old Oct 6, 2008 | 10:30 AM
No... The petcock is spewing fuel when opened. I got her running now. She is still sluggish and wonat to kill out if I rev her hard... Could it be my spark plugs. It did run out of gas.
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
