Front rotors question
Old Dec 26, 2012 | 05:02 AM
nguyen925's Avatar
Default Front rotors question
My Left front rotor on my 99 F4 is warped and I'm trying to buy a new one, I was wondering what is compatible with my rim? I have a OEM rim. Tried ordering a set on ebay but they turned out to be the wrong ones. Any help would be appreciated thanks!
Old Dec 26, 2012 | 10:47 AM
gotcbr's Avatar
The OEM rotors are excellent.
Galfer rotors are nice (& pricey).
EBC make rotors for the F4 as well.
I never buy vital components from ebay unless I know the source. You can get the above from your local dealer, bikebandit, ronayers, motorcyclesuperstore, etc.
Old Dec 26, 2012 | 10:55 AM
CJardine's Avatar
Track junkie & modaholic
I have a set that I wont be using, they arnt brand new but they are straight and true.
Old Dec 27, 2012 | 11:26 AM
nguyen925's Avatar
pmed you CJ, gotcbr are the front rotors interchangable? I read on fireblades that the arrows are only for aesthetics.
Old Dec 27, 2012 | 12:43 PM
gotcbr's Avatar
Yes, they'll work on either side but once they've been run on a particular side, they need to continue to be run that way due to pad wear.
Old Dec 27, 2012 | 02:54 PM
Dean0's Avatar
I was told that the rotors were handed so that the drilled pattern of holes went through the pads in a particular direction.
The normal way of rotation has the inner ring of holes meeting the pads first
When you run in reverse - the outer ring of holes meets the pads first.
Something to do with less ****** and a smoother feel on the brakes when run the correct way
riegnman
Jun 26, 2011 07:45 PM
Acingteam
Jun 5, 2008 04:15 PM
