91 front rotors on an '87?
Old Jul 11, 2008 | 10:12 PM
riegnman's Avatar
Default 91 front rotors on an '87?
Does anybody know if the 91 front rotors will fit on an '87 model? I REALLY need rotors badly. Thanks.
Old Jul 11, 2008 | 10:13 PM
riegnman's Avatar
Default RE: 91 front rotors on an '87?
or if the 600f rotors will work on a 1000f of the same year.
Old Jul 12, 2008 | 02:29 AM
tallenuf's Avatar
Try looking up the part numbers for the rotors on www.mrcycles.com or www.bikebandit.com. These two sites have exploded parts drawings for all the different assemblies on the bike. If the part numbers are the same from year to year for your rotors you know you're good to go. Part numbers do carry over several model years in many cases for particular parts. Good luck.
Old Jul 12, 2008 | 06:59 AM
riegnman's Avatar
Thanks. That's what I needed. The part numbers didn't coincide. Oh well, back to the old drawing board.
Old Jul 12, 2008 | 10:09 AM
Steve_Cardiff's Avatar
Why can't I post? Riegnman - pm me please.
Old Jul 12, 2008 | 10:19 AM
All CBR1000 discs will fit from 87 to 99.
600 discs won't
Old Jul 12, 2008 | 12:30 PM
pacojoseph's Avatar
Dom't despair. 91 front rotors should work on an 87. Even though the Honda part numbers are different, if you check EBC Brakes' website, both years take the same aftermarket rotors. Thus they should have the same mounting pattern and disc thickness. This is not true for the 600, though.
Old Jul 26, 2008 | 06:11 PM
Juliet's Avatar
Default RE: 91 front rotors on an 87
I am posting this reply on behalf of Steve_Cardiff
The EBC part number for our discs is MD1008 (LS + RS for left and right) Other manufacturers might have a different code but the essential bit is the number 1008.
Cbr 600 discs wont fit but heres a list of those that will
These are UK models so you’ll have to find out the U.S. equivalent ie our Honda ST1100 is called a Pan European. I think its something else in America yes??
CBR1000 FH-FX 87-99
NT650 Deauville VW-V4 98-04
CB750 F2N-F21 92-02
VFR750 FJ-FP 88-93
ST1100 Pan European (ABS-TCS) AT/AV/AW/AX/AY/A1 96-01
Good luck.
Old Jun 26, 2011 | 01:37 PM
BillHamlin's Avatar
Can someone post the actual bolt circle for a CBR1000F disk? Are they all the same? Apparently that are flat with no dish. My '88 is anyway.
It would be a nice thread to find other part no.s that would bolt on.
Old Jun 26, 2011 | 04:22 PM
pacojoseph's Avatar
See my post here- https://cbrforum.com/forum/cbr1000f-...-rotor-126863/
