Front rotors question
I was told that the rotors were handed so that the drilled pattern of holes went through the pads in a particular direction.
The normal way of rotation has the inner ring of holes meeting the pads first
When you run in reverse - the outer ring of holes meets the pads first.
Something to do with less ****** and a smoother feel on the brakes when run the correct way
