front end tweaked....
so i put my self made slip on's on today, after removing my front fender and headed to oceanside, but came to notice my front wheel and handlebars were not aligned.
i noticed as i was driving straight my left bar was an inch or so back. so i parked my bike and turned the bars straight and say my front wheel turned.
my question is what could be or would be bent...? any thoughts or ideas...?.... after i get the bike home i will most likely park it till i can take it to a shop to have repaired. (depending on what all is entailed in the repair of this).
The clipons (bars) should have an alignment bb on them so they should always be in the same spot in relation to the fork unless someone has ground them off. Most likely a fork tube twisted in the upper or lower clamp and they are out of alignment. It can be tricky but if you take your time you can get it all straight yourself, or shops do it also.
thanks for the replies. i took 'er in yesterday where the owner/mechanic said basically the same thing... he gonna put it up on lift, secure it, loosen everything then shake it a lil and everything should fall back into alignment... (so he says) then retighten everything and go from there.
if there is more than meets the eye he will call me and let me know before proceeding.
(crossing my fingers it is nothing more) lol
again thanks for your input.
personally there are somethings i do not like to attempt working on when I lack the knowledge. ask me about a head gasket job on a honda import car and i got this one in the bag. lol
j.s.
thanks again all I will keep you posted.
j.s.
j.s.
j.s.
Good luck
the shop called . . .
she's ready for pick up.
turns out it was just the forks twisted, and after putting 'er on the lift and loosening everything then letting it self readjust and tightening everything up, all is good.
ill pick 'er up tomorrow and will post pics with my self made slip on bars.
shawnhpi
03-23-2007 01:36 PM
