Flush & fill coolant
Old May 17, 2012 | 08:40 PM
Turbulenz's Avatar
Official Welcome Crew
Default Flush & fill coolant
So I'm planning on flushing and filling the coolant on my f4 soon. I will be using premix Honda Pro HP coolant. I want to put an additive in to lower temps as much as I can.. I have had.luck with water wetter in the past with cars. With is better? Engine ice or water wetter? Are they both compatible with the Honda coolant? I don't ride in the snow but It does get cold in the winter.. I have ridden in mid to high 30s before.. So I do need antifreeze capabilities.
Any info appreciated.
Old May 17, 2012 | 08:57 PM
74demon's Avatar
Stick with honda coolant. It will work fine. But if you want to go the other way, engine ice works good on the street.
Old May 18, 2012 | 03:33 PM
Turbulenz's Avatar
thanks.. I'm going to stick with the Honda coolant.. Is it okay to mix engine ice with it? How much will I need (ratiowise). Is engine ice better than Water wetter? I've never used EI before.. that's all...
thanks
Old May 18, 2012 | 03:36 PM
74demon's Avatar
engine ice is supposed to be run all by itself. water wetter is supposed to have a little coolant mixed with it and water.
Old May 18, 2012 | 03:53 PM
gotcbr's Avatar
I'm a huge believer in both ProHonda 50/50 coolant & WaterWetter.
I've run WW & distilled water mix at Willow in 100+ temps (track temp much higher than that) all day long w/ nice stable engine temp.
You can mix WW & 50% or less ProHonda for optimum street protection w/ varying temps & cooling ability.
Redline (WW producer) has good info on their website... Red Line Synthetic Oil
zbake
Feb 23, 2013 11:09 PM
lap9387
Aug 6, 2012 04:14 PM
jlpinedas
How To's
Jul 16, 2012 10:18 PM
bwaters932
F2 Tech
Apr 3, 2011 12:18 PM
NE1000F
Jan 5, 2010 03:27 PM
