Fan Setting
Old Jul 14, 2008 | 02:50 PM
ThatIsSosteve's Avatar
Default Fan Setting
how can i change the fan setting to turn on the fan at 1/2 temp or below instead of 3/4?
Old Jul 16, 2008 | 08:30 AM
MartiniRossy's Avatar
Default RE: Fan Setting
Not possible I think, unless someone makes a programmer for the PCM on these bikes but I doubt it since they're not fuelies. You could fool it with the right resistor in parallel with the wires on the temp sensor but that's probably not a good idea. I've heard of guys making toggle switches for fans but that will definately suck the first time you forget to turn it on. Any reason why you want it to turn on sooner?
Old Jul 16, 2008 | 08:48 AM
i don't know how to set up the toggle switch, could you help me out on how to do it? my bike won't run good when it's pass half of heating temp.
Old Jul 16, 2008 | 02:10 PM
You might need some carb work in that case or some other issues. Email me at ross.dolly82@yahoo.com and I'll send you a little diagragm of what you need to do. If you are night familiar with electronics you might want to have someone who is help you out.
CJardine
How-To: Mechanical
Oct 27, 2013 03:01 PM
coalminer frank
F2 Tech
23
Jul 16, 2012 10:30 PM
cbrchaz
Apr 10, 2008 03:18 PM
mark5009
May 4, 2007 08:05 PM
ta2av
Jan 3, 2006 07:10 PM
