F4 forks what fits?
Old Oct 6, 2012 | 09:03 PM
RobertT800's Avatar
Default F4 forks what fits?
Just as the title says got a f4 2000 which I crashed as some of you may know and need to get some forks to put on it to use for winter so I can put my r6 away :/ what forks will fit from other years or bikes ? Thanks
Old Oct 6, 2012 | 09:07 PM
gotcbr's Avatar
I've written on this b/f...
You can use 1999-2000 F4 forks or 2001-2006 F4i forks. Externally, they are identical. Internally, there are minor differences. They are plug-n-play/swap-n-go. ;-) FWIW, my spare forks are F4i forks & I routinely swap them out on my F4 when I have my F4 forks out for servicing.
You should be able to find F4i forks fairly easily.
Old Oct 6, 2012 | 09:54 PM
RobertT800's Avatar
Wicked thank you
Old Oct 6, 2012 | 10:03 PM
RobertT800's Avatar
Oo and sorry but will any other bikes forks fit?
Old Oct 6, 2012 | 10:54 PM
gotcbr's Avatar
As direct replacement, not really any w/o adaptation/modification. FYI the F4 & F4i forks are 43mm.
If you want to do a front end swap, you could do what CJ did w/ the 1000RR USD forks but there's quite a bit more involved than just a direct swap & it gets pricey.
So if you want to do the most avail, lowest cost, & easy replacement, F4i forks are the way to go.
Acpower
Nov 13, 2012 09:08 AM
TooBroke0029
Aug 28, 2010 04:01 PM
jfunkRR
Apr 30, 2008 09:23 AM
06CBRF4i
Jul 26, 2007 02:04 AM
