f4/f4i front conversion
Old Nov 7, 2005 | 12:39 AM
LikitySplit's Avatar
Default f4/f4i front conversion
This year in may i recently bought a 2000 f4 i want to do an 01-03 f4i front conversion what parts exactly will i need.i know i need the headlight,upper fairing,faring stay and what else?and will this stuff bolt right on? help help help
Old Oct 18, 2006 | 04:26 PM
429dhm's Avatar
Default RE: f4/f4i front conversion
Does it fit. I am thinking of the same mods
Old Oct 18, 2006 | 06:52 PM
cbrwrx's Avatar
i did the front and rear conversion on my bike. for the front, the f4 gauges won't fit in the f4i stay, im pretty sure you could make a bracket and mount them in there, but it won't look as clean. Also, the ram air tube covers are different, as well as the windscreen, i kept my ram air tubes but the f4i uses different tubes and vents up front. The wiring harness for the headlight is also different since the f4i has the dual bulb setup. If you get all the parts, it all bolts together, you just need to wire it all up.
catworst
Alternative Parts
Feb 21, 2021 02:03 PM
CBARE
Jul 23, 2011 11:02 AM
polarpanther
Apr 27, 2011 01:28 AM
chuckd
Aug 4, 2009 09:37 PM
rothjl749
May 10, 2009 11:33 AM
