F4 Chain Replacment
F4 Chain Replacment
So I think I have been running around on borrowed time enough. I need to change my chain. I want to ask you guys if this is a good replacement or should I get something else? Also what type of grease should I use on the front sprocket? Want to try and get everything I need as I'm going to be working out a storage unit and the bike is my transportation obv.
HARD RACING PERFORMANCE / HARD CORE SPORTS SHOPPING CART - CHAINS & 520 Sprocket/Chain Conversions & Chain Breaker/Rivet tool
They have both RK and DID chains, They have good deals on the other chain/sprocket combos as well if you really need to save $$. If you tell them how many links you need and that you don't have a tool they should cut your chain for you, or I have one you can use.
Edit: Actually you know what I have a kit for an f4 that I can't use. It's a DID chain with Renthal sprockets. If you want it it's yours. 15t steel in the front and 45t aluminum in the rear.
let me know
mike
