Transmission replacment
Old Apr 11, 2009 | 08:17 PM
morbidphil0622's Avatar
Default Transmission replacment
My bike pops out of second gear.. Assuming that the shift fork is bent I would like to replace it. I have a complete motor from a wrecked f2 (minus the head) that has a trans in perfect condition..
my question is will it be easier to just swap transmissions or should I just replace the bent fork and gear thats causing the problem?
Has anybody written a "How to" on shift fork replacment? If no then does anybody know of a manual that will give me the best instructions on how to do this? Not just a few pictures and a paragraph.. Thanks very much...
Old Apr 11, 2009 | 11:33 PM
Sand.Man's Avatar
Being a cassette style transmission, it's fairly easy to swap the new for the old.
Have you considered swapping the head from your running motor over to the wrecked engine and avoid splitting the cases?
If you decide to swap trans parts let me know and i'll guide you through the process.
Old Apr 11, 2009 | 11:49 PM
I would love to swap motors but the casing on the clutch side of the donor motor is pretty messed up.. Its pretty much beyond anything I would want to repair. the good news is that I always have tons of extra parts if I need them..
As for the parts swap I am going to go through with it so any info will be appreciated..
Old Apr 12, 2009 | 12:08 AM
Sand.Man's Avatar
I'm going to sleep now, but I will help you as much as possible.
When you're ready, begin by removing all bodywork and electrical components from the subframe and motor.
You'll be pulling the engine out of the frame so be sure you have a large clean work space to do this in.
Equip yourself with some masking tape and a sharpie marker, as well as a box of ziplock bags to keep everything organized.
Label the electrical connections with the masking tape so you know how everything goes back together, and keep bolts/small components in the ziplock bags (labelled).
Old Apr 18, 2009 | 04:31 PM
I did however fail to mention that my current shift pattern is 1 up and 5 down GP style. Is this going to affect anything at all? I would also like some input on what repair manual would be most helpful if it is at all possible.. Thanks again.
Old Apr 18, 2009 | 07:35 PM
Sand.Man's Avatar
So does it pop out of second gear, or is it hard to get into second?
Old May 3, 2009 | 02:00 PM
I can shift into second but it will not fully engage. The bike makes a violent rattling sound like something isnt quite catching.. I just skip second gear and keep on going..
Old May 3, 2009 | 02:14 PM
Sand.Man's Avatar
Hrmm, could be a few things... None of which you will want to deal with lol.
Shift fork, worn dogs, worn shift drum...
Old May 3, 2009 | 02:38 PM
My best guess is that one of the forks is bent but I am not a doctor so I think I just need to open her up and do some brain surgery to try and see what is wrong.. lucky for mr i have a perfectly good donor trans to swap out for.. Now I know that I am going to have to drop the motor which is cool because I would like to clean her up a bit anyhow, but I am hoping that I can access everything through the oilpan and clutch area so i dont have to split the cases.. Would this be practical at all?
Old May 3, 2009 | 03:28 PM
Sand.Man's Avatar
Will need to split the cases, be sure to flip the engine upside down (resting on the valve cover) when you split the cases.
mikesx4911
Nov 21, 2013 09:18 AM
scorpionvmu
Jul 2, 2011 09:07 AM
Riderc82
Mar 18, 2009 03:20 PM
92cbr900
Aug 28, 2007 01:35 AM
Royce
Apr 7, 2006 06:13 PM
