Driving issue
Old Jul 27, 2011 | 08:49 PM
JGray30's Avatar
Registered Users
Default Driving issue
When I run my '99 F4 and get it all warmed up and the hotter it gets it seems to stutter and hesitate at take offs n almost stall out. And I dunno if it's just me but it seems that the performance just declines
Old Jul 28, 2011 | 05:29 AM
highwaypatrol's Avatar
It's a bit difficult to diagnose this type of problem online, as there so many things that could be causing your bike's symptoms. Spark plugs could be breaking down or they might need a good clean and the gaps checking. Is the bike overheating? Not sure if your model has a temperature gauge, but I feel it must have. If it overheats and the fan doesn't kick in that might cause your loss of power. A break down somewhere in the fuel or ignition system might also be a factor. Sorry I can't be more specific, but I'll keep my thinking cap on!
Old Jul 28, 2011 | 08:56 AM
JGray30's Avatar
Registered Users
I kno I need a new clutch.. But I just recently changed plugs a month ago. Ima check them this weekend.. Get a new fuel filter.. Try n give it a work over see if I can discover anything
Old Jul 28, 2011 | 01:23 PM
gotcbr's Avatar
Originally Posted by highwaypatrol
It's a bit difficult to diagnose this type of problem online, as there so many things that could be causing your bike's symptoms...
I have said this so many times. While I try to help as much as possible, it can be tedious to work thru a problematic issue(s) w/o having the full picture. I've had some members take the problems offline w/ me & exchanged dozens of emails to fix them...only to find out as we go along, that there's other problems that weren't mentioned originally...& that changes the original diagnosis & delays the fix. :\
I try to always recommend that the OPs of these type threads do their proper troubleshooting procedures first b/f just posting up -part- of the problem.
So... OP don't take my comments above as what you are doing specifically. However, take some time to review & research thru the factory Honda service manual on your own. There are links here on the forum to download the pdf file. See if there are other distinguishing factors/problems to your situation & report back.
dr2i4ve
Oct 26, 2010 10:05 AM
jamefs912
Dec 9, 2009 03:40 PM
StangLou
Sep 1, 2007 08:49 AM
gerharddvs
Jun 29, 2007 11:11 PM
Patrick
Apr 28, 2005 08:57 PM
