Digital clocks...
Old Mar 31, 2010 | 03:06 PM
RoofRider's Avatar
Default Digital clocks...
was wondering if anyone here on the forum was doing this sort of mod... I mean is it possible to fit in the digital speedometer (tacho) to 1999 cbr f4 ???
Old Mar 31, 2010 | 06:15 PM
dmcb2120's Avatar
yep I did . You need a F4i speedo .
Old Mar 31, 2010 | 09:43 PM
scott07's Avatar
you could look at the ones from veypor, you can just google it. They do alot and are universal.
Old Mar 31, 2010 | 10:11 PM
jonld's Avatar
Both mentioned will work, however the f4i tach is not digital, just the speedo.
Old Apr 1, 2010 | 11:43 AM
RoofRider's Avatar
:thanx very much lads on other forums I simply get answer WHY??? hehe can I get any pictures of Your mod with that F4i clocks pls? or even quick description of what ye have 2buy, and what ye have 2do... I have found some info bout that vapor yoke here:
http://veypor.com/forum/viewtopic.php?t=198
Old Apr 1, 2010 | 11:58 AM
RoofRider's Avatar
ohh ye one more thing.I have found something like this... is that any good?
http://cgi.ebay.ie/SPEEDO-CLOCKS-SPE...2#ht_500wt_956
Old Apr 1, 2010 | 12:14 PM
gotcbr's Avatar
Be sure to keep up w/ your mileage once you change over. ;-)
Old Apr 1, 2010 | 12:25 PM
RoofRider's Avatar
is that change over difficult? or it's just simple swap... I mean are this connectors from F4i the same as in F4? or I have to do something with it? anyone have a guide how to do this...?
Old Apr 1, 2010 | 01:24 PM
RoofRider's Avatar
ok.... so I started to gathering some info on this one:
1. I need the F4i clocks
2. I need F4i thermostat (complete with sensor) and a new gasket for the thermostat
got some helpfull info from here:
http://cbrworld.net/forums/6/219055/ShowThread.aspx
Old Apr 1, 2010 | 02:18 PM
RoofRider's Avatar
here are the wiring colours for F4 and F4i models.
F4 F4i
Temp G/Bu G/Bu
Speed P/G P/G
IGN Bl/Br Bl/Br
20km/h P/Y ?
Illumi Bl/Br Bl/W
Batt R R/G
Turn R Lb Lb
Hi Beam Bu Bu
Neutral Lg/R Lg/R
Oil Bu/R Bu/R
Tacho Y/G Y/G
Sensor G/Bl G/Bl
Turn L O O
Res Sensor Br/Bl Br/Bl
Color code:
Bl - Black
Br - Brown
Y - Yellow
O - Orange
Bu - Blue
Lb - Light Blue
G - Green
Lg - Light Green
R - Red
P - Pink
W - White
Gr - Gray
F4i Colour code is the same as above.
Now as you can all see I have done some reserch on this wiring have one question mark there... 20km/h on F4,whats that correspond on F4i?. I gues that I
dont have to use Fuel injection indicator at all couse I have carbs. whats the story with that side stand on F4i? (G/W) just wire it to the side stand
separately? the rest of wiring is preaty straight forward...
