Digital clocks...
was wondering if anyone here on the forum was doing this sort of mod... I mean is it possible to fit in the digital speedometer (tacho) to 1999 cbr f4 ???
yep I did . You need a F4i speedo .
you could look at the ones from veypor, you can just google it. They do alot and are universal.
Both mentioned will work, however the f4i tach is not digital, just the speedo.
:thanx very much lads :icon_wink: on other forums I simply get answer WHY??? hehe can I get any pictures of Your mod with that F4i clocks pls? or even quick description of what ye have 2buy, and what ye have 2do... I have found some info bout that vapor yoke here:
http://veypor.com/forum/viewtopic.php?t=198 |
ohh ye one more thing.I have found something like this... is that any good?
http://cgi.ebay.ie/SPEEDO-CLOCKS-SPE...2#ht_500wt_956 |
Be sure to keep up w/ your mileage once you change over. ;-)
is that change over difficult? or it's just simple swap... I mean are this connectors from F4i the same as in F4? or I have to do something with it? anyone have a guide how to do this...?
ok.... so I started to gathering some info on this one:
1. I need the F4i clocks 2. I need F4i thermostat (complete with sensor) and a new gasket for the thermostat got some helpfull info from here: http://cbrworld.net/forums/6/219055/ShowThread.aspx |
here are the wiring colours for F4 and F4i models.
F4 F4i Temp G/Bu G/Bu Speed P/G P/G IGN Bl/Br Bl/Br 20km/h P/Y ? Illumi Bl/Br Bl/W Batt R R/G Turn R Lb Lb Hi Beam Bu Bu Neutral Lg/R Lg/R Oil Bu/R Bu/R Tacho Y/G Y/G Sensor G/Bl G/Bl Turn L O O Res Sensor Br/Bl Br/Bl Color code: Bl - Black Br - Brown Y - Yellow O - Orange Bu - Blue Lb - Light Blue G - Green Lg - Light Green R - Red P - Pink W - White Gr - Gray F4i Colour code is the same as above. Now as you can all see I have done some reserch on this wiring :) have one question mark there... 20km/h on F4,whats that correspond on F4i?. I gues that I dont have to use Fuel injection indicator at all couse I have carbs. whats the story with that side stand on F4i? (G/W) just wire it to the side stand separately? the rest of wiring is preaty straight forward... |
