Dent in gastank.
Old Jul 11, 2012 | 10:09 AM
EViR's Avatar
Default Dent in gastank.
Yep topic says it all, wasnt from me any idea what i could do besides buy a new one lol.
Think a shop could get it out???
Old Jul 11, 2012 | 10:21 AM
Andr3w's Avatar
Body filler, sand, paint, etc.
I've also heard about putting water in the tank then freezing it in attept to pop the dent out.
Old Jul 11, 2012 | 10:55 AM
EViR's Avatar
Interesting
Old Jul 11, 2012 | 02:40 PM
jeffjones's Avatar
Is the paint cracked?
If not look for a paintless dent removing shop and they can probably do it.
Old Jul 11, 2012 | 04:12 PM
gotcbr's Avatar
^ What jeffjones said. I've seen those guys work wonders!
Old Jul 15, 2012 | 09:04 PM
LetoCharles's Avatar
i know of a few different options depending on where you want to go with it
-body filler and repair paint-..this works, does require paint work but you still have a dent and depending on the severity could effect fuel level and mileage.
-repair the dent-.. my opinion would be to grind to bare metal, weld a stud on and pull the dent with a slide hammer as is usually done with dents at body shops to pull panels, you would then need a thin layer of body filler and sand/prime/paint to finish the repair.
-freezing water in the tank-..i know some harley guys that have done this with success, remove and drain the fuel tank, fill with water, seal and leave in freezer. as the water freezes and expands it should push the dent out, i would keep an eye on the tank and as soon as the dent pops pull the tank out and allow to thaw so it doesnt push anywhere else out, you do however run the risk of something being pushed out that you don't want pushed out.
-paintless dent-...this will work as long as the dent is somewhere that the paintless guys can get to through the fuel cap and repair without distorting the seal for the filler cap
best of luck, if possible post up some pictures of the dent
kerosene
Sep 11, 2013 08:40 PM
f3Rider97
Aug 11, 2011 09:14 PM
infinity101
Sep 15, 2010 01:15 AM
ta2av
Aug 24, 2005 05:12 PM
