coolant leak at high speed
Old Mar 22, 2026 | 07:12 AM
TiagoRodrigues's Avatar
Exclamation coolant leak at high speed
When I go up to 200km/h and stop the bike, i notice some coolant under the thermostat. At first I thought it was from one hose that connects to the waterpump, but it has no leaks. It also has some oil leak but i think it is from the stator cover that I'm going to replace it. can anyone
help me?
view from the left side of the bike, the red thing is the rear shock just for reference
same place different angle
It's not a lot of cooolant but I'm afraid that something worse might happen. thank you.
Old Mar 23, 2026 | 09:46 AM
cbr600f4 project's Avatar
Where is your coolant overflow tank/ reserve tank located? Also, where is the emergency overflow dumping out at? I would check both of these first, as they are an easy fix, or don't need any fix at all. I have experienced something similar when I let my bike overheat while sitting in the garage chasing a wiring issue. The coolant boils over from the radiator and main system to the reserve/ overflow tank, and then it can start spraying from the overflow line due to the steam and heat pressure from inside the system. I would assume after 200+ km/h, it would be running pretty hot, and could be spraying coolant out of that overflow line.
SunBlue
Jul 9, 2017 09:02 AM
spaishon
Mar 17, 2011 07:23 AM
95teggy
Feb 26, 2011 01:37 AM
nsilva
Aug 23, 2010 06:08 AM
mattyg
Apr 26, 2007 02:58 PM
