common for oil to smell like gas and have a little gas in it?
Old Dec 10, 2011 | 12:42 PM
cBrentb's Avatar
Exclamation common for oil to smell like gas and have a little gas in it?
I changed my oil three weeks/ 7 hundred miles ago with amsoil 10/40 and honda filter. now it has a slight/ hint of gas smell.i oil cap and smelled it then took some out to examine. it still smells more like oil than gas, like it should, has not broken down viscosity. like i said its not an over whelming smell of gas in the oil its just a slight smell. is this normal or should i be worried?
Old Dec 11, 2011 | 11:31 AM
cBrentb's Avatar
i mean, has anyone here had fuel get into the crank case on thier bike before? and what was the cause? how did you fix it?
Old Dec 13, 2011 | 09:54 PM
MZ5's Avatar
MZ5
It's not abnormal.
A certain amount of unburned fuel will get past the rings and into the crankcase. You can have the oil analyzed to tell you just exactly how much is there if you like. Such an analysis would cost anywhere from ~$10 to ~$125 (which will get you a lot more info, too). You don't _want_ fuel in the oil, so the less the better. Nevertheless, my experience is that it's not uncommon for oil to have a slight to moderate fuel smell, and for the actual fuel content to be up to a couple percent fuel (again, less is better as the fuel interferes with the oil doing its job of lubricating).
Dazed
Feb 19, 2013 04:50 PM
bdahl77
Jan 11, 2011 10:21 PM
hondachris1994
Mar 13, 2009 08:05 AM
bignibb
Oct 3, 2007 03:52 PM
K0NPHL1C7
Sep 16, 2007 08:28 PM
