charging problem in 99 F4
Problem: battery doesn't charge
cannot start after stall
when coming to a stop down a hill bike stalls even with 2500rpm idle
What I've Done: Hooked up a multi, at 2000rpm it read 14.2V for about a second then changed to 11.2V where it stayed. I rev it up (5000rpm) and it stays at that voltage.
The battery is 10.8V with bike off. Won't crank over of course.
Battery brand new. Worked fine when it was initially put in.
Solution: Since i'm new to motorcycles but not cars. I guess it would be the alternator if it were a car. Until I research and find there are more electrical components for the bike. I would like to know what you all think needs to be replaced?
The part I do not get is that the multi read 14.2V for an instant then it would go straight to 11.8 ? Could it be a regulator? I kept connecting and disconnecting the multi and it usually read 11.8 but sometimes it would flicker from 14.2.
This is my DD and i cannot afford a shop to repair it right now. So unless I can figure out what it is I might have to take it in for diagnosis!
Please Help!!!
Thanks.
Please Help!!!
Thanks.
Yeah, I had this problem about 2 years ago. My problem was once the bike and regulator got hot, the charging system couldn't hold 12v at idle. I checked the stator and it was putting out the correct voltages and wasn't shorted. So I put a new regulator on (new style stock cbr one). About a month later, started having the same problem again. Checked stator, still doing what it should, so only other suspect was the regulator. I put a new style FH012AA (yamaha part number) regulator on mine a few weeks ago, and haven't had any problems with charging system yet. It uses a mosfet chipset, so it's way more efficient at converting A/C voltage to DC voltage withing wasting a lot of it to heat.
