Chain Replacement
RE: Chain Replacement
Yes do both. From what I hear on here and have read up all over the net, it is best to change both at the same time. This makes sure that you will get the best life out of which ever one truly needs changing. I've also checked around on prices and it seems sprocketcenter.com has the best package deals as well as being able to accomidate if you are wanting to +/- any teeth, I think they even adjust the chain length for those mods too.. Good luck shopping and ride safe..
+1 on www.sprocketcenter.com
and yes you are suppose to change the sprockets at the same time. you can buy the whole set from that place or buy the sprockets individually.
