CBR 600FY (2000) engine ticking noise
Old 08-19-2012, 04:48 PM
Drewie's Avatar
Default CBR 600FY (2000) engine ticking noise
Hi everyone, recently changed oil, oil filter, coolant and spark plugs to my bike and have noticed a random ticking noise coming from the engine when idling. This can only be heard when the engine warms up and does not get any worse when turning the throttle.
Definetly correct oil level in bike and checked the spark plug gaps before fitting them.
Ive been reading on here that these bikes have a common fault with the cam chain tensioner, could this be it? As I said it only happens when the engine has warmed up and cant be heard when increasing revs, hmmmmmmmmmmmmmm.
Any suggestions would be most grateful
Cheers all
Old 08-19-2012, 05:17 PM
gotcbr's Avatar
Sounds like the CCT.
Old 08-20-2012, 01:11 PM
Drewie's Avatar
Thanks for your reply gotcbr
If it is the cct should it get louder with increasing revs as I have read on some threads. Mine doesent get louder with increasing revs and just randomly and annoyingly ticks at ide only when the engine is warm.
Old 08-20-2012, 01:28 PM
gotcbr's Avatar
Seems its dif from bike to bike w/ CCTs. Its possible to go many thousands of miles w/ it remaining like it is. It will be more of a slight annoyance than a true problem.
Old 08-20-2012, 05:44 PM
Drewie's Avatar
Yep, could well be it and it wont stop me using it. I fitted a complete new exhaust a few months back and was wondering if it could be the manifolds blowing slightly as apparantley they can make a ticking noise aswell. Just seems strange that it only happens when the engine is warm. Going to check em tomorrow just incase
Thanks for your help anyway.
Old 08-20-2012, 08:38 PM
CJardine's Avatar
Track junkie & modaholic
What type of oil did you put in? And get a mech stethoscope or a long piece of tubing. Put one end to your ear and use the other to find where the noise is coming from.
Old 08-22-2012, 03:13 PM
Drewie's Avatar
I used a 10w40 semi synthetic oil and I checked the API grade was correct. Ive tried what you said and it sounds like the tapping is coming from the cct area.
Ide like to change it anyway just to eliminate it as it sounds like a very common problem.
According to my service manual it says to line up the timing marks on the inspection cap outer marks and also on the camshaft sprockets before changing the cct.
Is this really necessary as ive spoken to someone with the same bike and he said he changed his without lining anything up. Did he get lucky?
Im not afraid to do things like oil changes and spark plugs but I wouldnt like to take of carbs etc to get at the sprockets incase I mess things up.
Thanks for any ideas
Old 08-24-2012, 03:02 AM
Drewie's Avatar
Any ideas please..............?
Old 08-24-2012, 03:48 AM
CJardine's Avatar
I replaced mine with a manual one and dont recall lining anything up.
Old 08-27-2012, 03:04 AM
Drewie's Avatar
Thanks, think ile order a new tensioner asap
rob_1990
03-16-2014 11:12 AM
tallenuf
09-13-2008 06:16 PM
1slowf4
06-10-2007 12:03 AM
1rubbersidedown
10-28-2006 09:26 AM
77vetteguy
06-29-2006 05:01 PM
Quick Reply: CBR 600FY (2000) engine ticking noise
