Cb600fx(f4 carb)
Old Apr 30, 2026 | 11:24 AM
ssray's Avatar
Default Cb600fx(f4 carb)
I'm having a problem getting my cbr600fx(f4 carb) carbs back on.When I first got it the carbs just pulled off, the clamps weren't at all tight.It took me ages, then I was told about the holes in the frame for extra long screwdrivers. Carbs off today as it has a mis fire, loose plug connector. I can got the outside carbs clamps into a position where I can get to them and tighten them . I can't get to the middle two, I've taken the carbs off a few times today and turned the clamps, I can't seem to get to them. Any ideas?Ta Ray
Old Apr 30, 2026 | 01:43 PM
I'm not quite following. You were able to get to the clamps in order to remove them, correct?
One thing, were you removing the carbs from the rubber boots and leaving the boots connected to the intake manifold? If that's the case, try installing the boots onto the carbs, then onto the manifold The bottom clamps are easier to get to.
Old Yesterday | 09:38 AM
Makes sense.
Since you inherited the issue, assume nothing is correct. Concerning the clamps on the boots, both upper and lower, the head of the screw for each should be facing out. If you picture the face of a clock, the screws should be pointing outward pointing towards about the 4 o'clock position. You will need a really long screwdriver of socket driver. I forget the size but I think it's 8mm.
I use a screwdriver set from Harbor Freight. The screwdriver is 22" long. Even with all that, you really have to get down and sort of make a pathway with the screwdriver.
Ricecooker
Oct 14, 2013 10:09 AM
MadHattr059
Sep 16, 2011 10:47 AM
kinglee86
Dec 28, 2010 05:58 PM
Knight2000
Sep 2, 2006 10:24 PM
F2Woody
Feb 4, 2006 03:17 PM
