Carb sync help
Old Mar 31, 2013 | 03:07 AM
cookml22's Avatar
Default Carb sync help
Ok middle of rebuild trying to sync the carbs not sure whitch hoses to use. Are they theses lines?
Or these?
Old Mar 31, 2013 | 05:10 AM
Fobwareagle's Avatar
Your vacuum gauges will be plugged into the 4 vacuum lines that end at the airbox. They are small, maybe 1/8" lines and are plugged in at and across the back of the airbox, left to right. You had to have unplugged them to take off the airbox.
Old Mar 31, 2013 | 06:50 AM
cookml22's Avatar
There wasn't four small lines on mine, I did find four small lines hooked to the bottom of each carb on the flot bowl that go to the intake to each carb, could these be the lines? And the po just put them in the wrong spot? If these are them ill be sure to put them where they go when I finish the sync
Old Mar 31, 2013 | 07:38 PM
stealthy92's Avatar
Yup those are them most likely. Previous owner of my bike had them set up the same. Like Fob said they go to the air box, not the carb bowl. Page 3-13 of the manual shows them and how to sync the carbs.
Old Apr 1, 2013 | 04:12 AM
cookml22's Avatar
Thank you found it
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
scottiekarate17
Jul 24, 2011 03:47 PM
dakers0010
Sep 15, 2010 09:23 PM
camaropower
Mar 31, 2009 10:23 PM
chrisf
Aug 4, 2006 11:15 AM
