carb swap?
Old Jun 18, 2011 | 12:47 AM
segraves1's Avatar
Default carb swap?
The diaphragms in my 99 F4's carbs are not in what I'd consider very good shape. The rubber is so wrinkled that the "lip" won't even fit into/stay in the carb body lip, which means the diaphragms probably won't seal right. Replacement diaphragms cost anywhere from $75 to $130 each depending on retailer, not to mention the other o-rings could be replaced as well. I could see myself spending $500 rebuilding some old used carbs.
So, I'm investigating different options.
I had looked at doing a fuel injection swap from the F4i, but then that needs another $1000 of add-ons to tune it (power commander III or whatever it's called). Not really digging that idea.
Another option was to find out if there are "better" carbs out there that I might run. Were the "older" 600 (or perhaps 1000) carbs "better" in some way? What about doing a total swap to perhaps a pair of higher CC carbs (1 carb = feed 2 cylinders)?
The last option revolves around my plan to do a turbo (just cause I want it). Instead of doing a blow through system (like I would do with the stock f4 carbs), I COULD dig up a single large turbo and make it pull through.
Again, just looking for options.
Chris
Old Jun 18, 2011 | 10:48 AM
gotcbr's Avatar
Sorry your carbs need the work. While I understand your plight, the 99/00 carbs were pretty much top of the Honda line for their day. I can't imagine that swapping to any "older" carb would be a gain. Instead, it would prob be more problematic in fitment & cost vs just rehabbing the orig carbs. Nevertheless, I look forward to your findinds & hearing what you decide to do.
Old Jun 18, 2011 | 02:04 PM
segraves1's Avatar
figures.... at least I have time to figure it out...
One problem I'm seeing is that because the "F4" carb only was in production for 99-00, there just are not that many out there. Looking at parts, the later "F3" carb looks very similar and there are quite a few on ebay for cheap. Just not sure if the F3 and F4 carbs are the same.
ic2283
Feb 3, 2010 02:46 AM
cba4
Sep 9, 2008 06:54 PM
ttyger07
May 16, 2008 02:27 PM
ttyger07
May 7, 2008 06:12 PM
jasonty
Jul 14, 2007 06:51 PM
