carb swap
Old Sep 8, 2008 | 02:33 PM
cba4's Avatar
Default carb swap
Will I run into any problems swapping the carbs from an 87 to an 88. There seems to be a small amount of difference in some of the internals but pretty close to the same.
Old Sep 8, 2008 | 03:20 PM
Hurricane rider's Avatar
Default RE: carb swap
I thought the 87/88 carbs were the same, 89/90's are slightly larger though. why swap same size carbs when you could put 89/90's in that have a 2mm larger bore?
Old Sep 8, 2008 | 03:52 PM
cba4's Avatar
I currently have stage 2 jetted carbs that I am trying to getting running correctly (running very rich) and have a set off an 87 for a good price.
How can I tell what year carbs are on the bike currently? It just occurred to me that I assumed they are the orig carbs.
Old Sep 8, 2008 | 05:07 PM
post the model numbers you find on the carbs. should be something like 20 and some other numbers I think. I believe the later hurricanes had VG21's or something similar.
Old Sep 8, 2008 | 05:39 PM
camoweasel's Avatar
only the 90s had bigger bore carbs, not the 89s.
Old Sep 8, 2008 | 05:58 PM
that was my bad. still not 10000% familiar with the Hurricane's heritage and evolution.
Old Sep 8, 2008 | 08:34 PM
cba4's Avatar
What other mods would i need to do if I switched to the 90 carbs and would it be worth it?
Old Sep 8, 2008 | 11:46 PM
tripicana's Avatar
the carbs are marked on the airbox side of the main body where the body and float bowl split. 87-89 are vg20a, 90 is vg26f.
i put 90 model carbs onto my 87 bike and the fit right in. the only other differences are the 90 carbs have two fuel inlets, one for 1&2, another for 3&4. the 87-89 carbs just have one fuel inlet between 2&3. the jetting is a little different also.
Old Sep 9, 2008 | 04:40 AM
camoweasel's Avatar
yes, may have to rejet a bit to make them run right.
Old Sep 9, 2008 | 06:54 PM
cba4's Avatar
I will probably run with what I have and just try and nail down my jetting issue.
Thanks
segraves1
Jun 18, 2011 02:04 PM
ic2283
Feb 3, 2010 02:46 AM
ttyger07
May 16, 2008 02:27 PM
ttyger07
May 7, 2008 06:12 PM
jasonty
Jul 14, 2007 06:51 PM
