Can't remove seat...
Old Dec 4, 2008 | 12:35 PM
rdlr's Avatar
Default Can't remove seat...
I have '99 CBR 600 F4. I installed fender eliminator kit and mini blinkers. Everything worked okay yesterday, but now I can't seem to remove the seat anymore. I think that the cable has somehow popped out from the lock (no resistance when I turn the key to open the lock).
What do I do now? I need to get the seat open... Any tricks or tips how to get the seat off without using brute force?
Old Dec 4, 2008 | 01:00 PM
94cbr600kid's Avatar
Default RE: Can't remove seat...
i have had the same problem on my suzuki gsxr.Can you look under the seat?..you should be able to see the cable.Get a long handle screwdriver (Or you may reach it with your finger) and pull up on the cable untill it releases..Hope this helps
Old Dec 5, 2008 | 09:23 AM
rdlr's Avatar
I managed to open the seat lock. I took off passangers hadle and used wire to get the cable trough handle hole.
Old Dec 9, 2008 | 02:41 PM
MartiniRossy's Avatar
Mine used to pop out of the holder by the seat latch also. I ended putting a couple of small wire ties around it so it would stay in place. Haven't had a problem since.
cjphoto
Nov 29, 2010 02:21 AM
ldebackker
Jul 31, 2010 04:10 PM
njdjh2o
Feb 25, 2008 11:46 PM
axsmoto
Oct 4, 2007 02:58 PM
garydogwood
Mar 17, 2006 01:24 PM
